Modify the display order for a field
A field can only have one display order, even if it appears in more than one context. You can set the display order of the standard and custom fields.
  1. In the left navigation pane, click the Settings icon (Settings icon).
  2. In the Configure System section, click Manage Topic Workflow Configurations.
  3. Click the configuration's Row Action menu (Row Action menu icon), and then click Edit.
  4. On the Edit Topic Workflow Configuration page, click the Fields card.
  5. Click the Modify Display Order link.
  6. The dialog box lists every field in the currently assigned display order. For each field, the identifying information appears as Display name [COLUMN_NAME] (ID=#).
  7. Select one or more fields.
    Tip:
    • Use the Up arrow and Down arrow keys to move the field up or down in the list.
  8. Click OK.
