Categorize Observations, Medications, Supplies, and Control Acts (Optional)
HDR 8.1 supports grouping data in certain general classes into subtypes, or categories. These categories follow the HL7 FHIR standard described here: https://www.hl7.org/fhir/codesystem-observation-category.html. You may need all, some, or none of these categories.
HDR 8.1 has a separate table to store data for each category. For more information about the tables, see the HDR Technical Reference Manual (eTRM) on the Oracle Help Center at https://docs.oracle.com/health-sciences/health-hdr-81/hdr-docs.htm.
To use categories, it must be possible to identify them in your HDR data. For example, to identify lab observations you may use ETS classifications or an attribute on the observation itself, like title.
You must edit the hdr8_acts_migration.sql migration script with appropriate filter conditions to separate the data into category tables.
- In the tables below, find the table name that stores data for a category you want to use. See Observation categories, Medication (Substance Administration) categories, Supply categories, or Control Act categories.
- Open hdr8_acts_migration.sql in a text editor.
- Search for:
AND 1 = 0 --modify the logic. - Replace
1 = 0 --modify the logicwith the filter condition and logic to write data to the appropriate table.For example, for extracting only laboratory observations into OHF_HDR_LAB_OBSEVN_RES table, customers who currently use ETS Classifications to main laboratory terminology codes can replace the condition 1=0 with the below condition with appropriate changes.
AND ACT_CODE_ETS_ID IN ( SELECT CONCEPT_ID FROM HCT_ET_CLSSFCTN_DCLRNS WHERE CLASSIFICATION_ID = ( SELECT CONCEPT_ID FROM HCT_ET_CONCEPTS_V WHERE CODINGSCHEME_NAME = 'ETSClassifications' AND CONCEPT_CODE = 'LAB_RESULT' ) );
Any data that is not categorized will be classified under the general category. Once the data is migrated to the category-specific tables, the RIM APIs support retrieval and persistence of data into the same tables using a special category attribute.
There are Observation categories for mood codes EVN, RQO, and DEF.
Table 7-1 Categories for mood code EVN
| Category (Subtype) | Table name |
General Observation Event |
OHF_HDR_OBS_EVN_RES |
Social History |
OHF_HDR_SOCHIST_OBSEVN_RES |
Vital Sign |
OHF_HDR_VITAL_OBSEVN_RES |
Laboratory |
OHF_HDR_LAB_OBSEVN_RES |
Procedure |
OHF_HDR_PROC_OBSEVN_RES |
Survey |
OHF_HDR_SURVEY_OBSEVN_RES |
Exam |
OHF_HDR_EXAM_OBSEVN_RES |
Therapy |
OHF_HDR_THERAPY_OBSEVN_RES |
Allergy |
OHF_HDR_ALRGY_OBSEVN_RES |
Diagnostic Report |
OHF_HDR_DIAGRPT_OBSEVN_RES |
Risk Assessment |
OHF_HDR_RISK_OBSEVN_RES |
Table 7-2 Categories for mood code RQO
General Observation RQO |
OHF_HDR_OBS_RQO_RES |
Diagnostic Order |
OHF_HDR_DIAGORD_OBSRQO_RES |
Table 7-3 Categories for mood code DEF
General Observation Def |
OHF_HDR_OBS_DEF_RES |
Data Element |
OHF_HDR_DATELE_OBSDEF_RES |
Table 7-4 Categories for mood code EVN
General Medication Event |
OHF_HDR_SBADM_EVN_RES |
Medication Statement |
OHF_HDR_MEDSTMNT_SBAEVN_RES |
Immunization Recommendation |
OHF_HDR_IMUNIZTN_SBAEVN_RES |
Table 7-5 Categories for mood code RMD
General Medication RMD |
OHF_HDR_SBADM_RMD_RES |
Immunization |
OHF_HDR_IMUNRCMD_SBARMD_RES |
Supply categories
Table 7-6 Categories for mood code EVN
General Supply Event |
OHF_HDR_SPLY_EVN_RES |
Medication Dispense |
OHF_HDR_MEDDISP_SPLYEVN_RES |
Table 7-7 Categories for mood code RQO
General Supply RQO |
OHF_HDR_SPLY_RQO_RES |
Nutrition Order |
OHF_HDR_NUTRORD_SPLYRQO_RES |
