How to uninstall HDR (if required)
Uninstall database objects
To uninstall the database objects (HDR, ETS and HDR_CONFIG user schemas), execute the following SQL scripts from sqlplus/sqldeveloper as the sys user:
If the tablespace names used during HDR install were different from the standard names then adjust the scripts accordingly.alter session set "_oracle_script"=true; set serveroutput on; declare
type tbs_name_type is table of varchar2(100);
tbs_names tbs_name_type;
begin
begin
dbms_scheduler.drop_job('HDR_ETS_MAINTENANCE', TRUE);
exception when others then
dbms_output.put_line(SQLERRM);
end;
begin
dbms_scheduler.drop_job('HDR_ETS_LOADER', TRUE);
end;
begin
dbms_scheduler.drop_job('HDR_ETS_IMPORTER', TRUE);
end;
begin
dbms_scheduler.drop_program('hdr_ets_maintenance_program');
end;
begin
dbms_scheduler.drop_program('hdr_ets_loader_program');
end;
begin
dbms_scheduler.drop_program('hdr_ets_importer_program');
end;
select tablespace_name bulk collect into tbs_names from DBA_TS_QUOTAS where username in ('HDR', 'ETS', 'HDR_CONFIG');
begin
execute immediate 'drop user HDR cascade';
end;
begin
execute immediate 'drop user ETS cascade';
end;
begin
execute immediate 'drop user HDR_CONFIG cascade';
end;
for i in 1..tbs_names.count loop
begin
execute immediate 'drop tablespace '||tbs_names(i)||'
including contents and datafiles';
end;
end loop;
end;
/Uninstall the HDR middle tier
To uninstall the HDR middle tier:
- Stop the hdr_domain and hdr_server node mangers.
- Delete the hdr_domain folder completely.
- Edit WebLogic Oracle_Home/domain-registry.xml and remove the entry for hdr_domain.
- Delete the HDR home directory (that you provided during installation) completely.
