Instance-Level Expunge Operation
post
/oracle-fhir-server/fhir/Device/{id}/$expunge
The $expunge operation can be invoked against a single Device resource instance, or even an individual version of a Device resource instance. If invoked at the instance level , previous versions of the Device resource may be deleted (if expungePreviousVersions is set to true) and the current version may be deleted (if the Device resource is deleted and expungeDeletedResources is set to true)
Request
Path Parameters
id(required): string
The resource IDExample:
123
Supported Media Types
- application/fhir+json
FHIR Parameters Resource
Root Schema : schema
Type:
objectFHIR Parameters Resource
Example:
"resourceType": "Parameters",
"parameter": [ {
"name": "limit",
"valueInteger": 0
"name": "expungeDeletedResources",
"valueBoolean": false
"name": "expungePreviousVersions",
"name": "expungeEverything",
"name": "count"
}Response
200 Response
Success
Root Schema : FHIR-JSON-RESOURCE
Type:
objectA FHIR resource
