Instance-Level Validate Operation
post
/oracle-fhir-server/fhir/Device/{id}/$validate
The validate operation checks whether the attached content would be acceptable either generally, as an update or as a delete to an existing resource.Modes update and delete can only be used when the operation is invoked at the resource instance level.
Request
Path Parameters
id(required): string
The resource IDExample:
123
Query Parameters
mode: string
mode parameter as a create, an update or as a delete.
profile: URI
Profile to be used to validate the resource.
Supported Media Types
- application/fhir+json
Device FHIR Resource
Root Schema : schema
Type:
objectDevice FHIR Resource
Example:
"resourceType": "Device"
}Response
200 Response
Success
Root Schema : FHIR-OperationOutcome-RESOURCE
Type:
objectOperationOutcome FHIR Resource
Example:
"resourceType": "OperationOutcome"
