Search by product and topic
You can also use My Oracle Support tools to browse and search the knowledge base.
To search by product or topic:
- Product Focus — On the Knowledge page under Select Product, type part of the product name and the system immediately filters the product list by the letters you have typed. (You do not need to type "Oracle.") Select the product you want from the filtered list and then use other search or browse tools to find the information you need.
- Advanced Search — You can specify one or more search criteria, such as source, exact phrase, and related product, to find information. This option is available from the Advanced link on almost all pages.
Parent topic: Find information on My Oracle Support
