Before installing the InForm Adapter software
Perform the following tasks before you install the InForm Adapter software:
- Enable XA transactions.
For more information, see Enabling XA transactions.
- Make sure that all clocks are synchronized on the machines on which you are installing the InForm Adapter interfaces, the InForm server, and the database server.
- Ensure the InForm database locale and the InForm Adapter Server locale are set to the same value.
- If you have any studies that have been decommissioned in the InForm software, run the Register Trial Tool to decommission the studies in the InForm Adapter software.
For more information, see Register Trial Tool.
- If you use certificate authentication, make sure TLS is enabled.
For more information, see Enabling TLS.
