Previous Topic
Next Topic
Book Contents
Deployment types
The InForm Adapter Coding interface supports network access directly to the server, network access through a load balancer, and local access. After you run the installation, you run a script at the command line, in which you state the type of deployment you want to use. For more information, see Choosing the deployment type.
Deployment types
Deployment name
HTTP / HTTPS
Authentication?
URL / SOAP study matching?
Default
HTTPS
Yes
No
Load balanced
HTTP *
Yes
Yes
LAN access
HTTP
No
No
* Represents the data sent by the load balancer to the API.
Send Feedback
