InForm Server Window services
In the table, a check mark indicates the service or services you require, depending on the InForm Adapter interfaces and Oracle applications you want to use.
The InFormAdapterWindow service is required by both Clintrial Ingegration Solution (CIS) and ODM. If these are needed make sure that the ISA service is running and set to automatic.
