InForm Adapter interfaces
You must install the InForm Adapter interfaces required by either:
- The Oracle application you are installing.
- The application or API you are developing.
The interfaces specified in the following table must be installed on the InForm Adapter server.
Product/interface installation requirements
To use this product or InForm Adapter interface |
Select these interfaces when you install the software on the InForm Adapter server |
Central Coding |
Clintrial Integration Solution (CIS) |
InForm Adapter Discrepancy interface |
InForm Adapter ODM interface |
