Specifying input parameters
- Expand the ODM 2.0 Parameters window.
- Select the attributes you want to use, and then collapse the window.
The table provides a brief description of each option. For more information, see the input parameters for each method in the InForm Adapter Interfaces Guide.
Attribute
Description
Mapping Vers.
The version of the InForm-to-ODM mapping. Specify 2.0 for the most complete and accurate representation of the InForm data that is returned in ODM format
Compliance Mode
Specifies how to handle transactions in the study that are deleted and then undeleted.
Strict
uses a Remove transaction to indicate that a form has been deleted. If the form is subsequently undeleted, the returned data includes all the data for the form that was deleted and then undeleted.Loose
uses aFormStatus
orItemGroupStatus
element with the attribute name ofDeleted
. Loose compliance mode is more efficient.Incl Extensions
Specifies whether to include Oracle ODM extensions in the data that is returned from the method.
PriorFileOID
Optional reference to the previous file (if one exists) in a series.
Request User Name
The user ID of the user who is requesting the data.
