Calling ODM Export methods
After you connect to an InForm study, you can use the ODM sampler tool to issue a request for the ODM Export methods.
The response XML for each method appears at the bottom of the sampler window, in a separate tab labeled with the name of the study and the method. You can select a tab and enlarge the view, save the response to a file, or delete the response.
