InForm Adapter interfaces to install
When you install the InForm Adapter application:
- The InForm Server Adapter (ISA) component is installed by default. The ISA is comprised of two services:
- The InForm Server Adapter Web Service.
- The InForm Server Adapter Windows Service.
For information about which applications or interfaces require one or both of these services, see InForm Server Adapter services.
- You must select the InForm Adapter interfaces to install. Install the interfaces that are required by either:
- The Oracle application you are installing.
- The application or API you are developing.
For the list of interfaces you need to install, see InForm Adapter interfaces.
