Installing a certificate for the InForm Publisher software
If the endpoint that the InForm Publisher application calls to update data to the subscriber destination requires a client certificate, you must set up a client certificate for the InForm Publisher Service to call the endpoint.
This is performed through the Certificates MMC snap-in in Microsoft Windows. Because the InForm Publisher Service runs as the local service user, you must add the certificate to the certificate store for the local computer for the InForm Publisher Service.
