Uninstalling the InForm Publisher software
To uninstall the InForm Publisher software:
- Rerun the installer wizard and select the Uninstall option.
or
- Run the SilentUnInstallInFormPublisher.bat file located in the folder where you extracted the InForm Publisher installation files.
Either method allows you to drop the Queueing Privilege Grantor user. The Queueing Privilege Grantor user can also be dropped by the database administrator.
