trial
The trial command allows you to view and modify study attributes. Use the trial command to define the list of studies that publish to the target application.
Descriptions of trial parameters
Parameter |
Description |
trial show |
Displays a list of subscribers associated with the study. Includes the following option: [trialName] where
trial add |
Adds the specified study to the specified subscriber. Includes the following options: [subscriberName] [trialName] where
trial remove |
Removes the specified study from the specified subscriber. Includes the following options: [subscriberName] [trialName] where
trial set |
Configures the attributes for a study. You can add one or many attributes. Includes the following options: [subscriberName] [trialName] [attr1=value1] where
trial setIA |
Not supported.. |
