ODM Snapshot format
The format of the ODM custom event extract XML conforms to ODM 1.3.1 with new extensions that do not exist in the ODM XML from InForm Adapter. The ODM XML is in the Snapshot format and compatible with the transactional output. The custom events extract is in CDISC ODM Snapshot format. InForm ODM extensions designed for InForm Adapter ODM transactional output are also supported and have been incorporated into this guide. Audit trails are not included in the ODM Snapshot format.
