Oracle extensions for ODM Snapshot
The ODM Extract Publisher is a unidirectional push of information that calls a web service, which a customer must implement to receive the CDISC ODM 1.3.1 Snapshot format. Refer to http:\\www.cdisc.org for more information on the ODM standard.
This section describes the Oracle extensions to the syntax and functionality of the ODM Extract Publisher of the InForm Publisher software. The ODM Extract Publisher focuses on the semantics of the function calls that are published by the interface, and the parameters that the published web methods use. Elements are included for:
- Custom events
- Clinical data
- Administrative data
- Metadata
Each section gives examples of XML for both the web method request and response.
