Choosing the deployment type
The User Management Interface software comes with:
- Three variations of the web.config file to support the different configurations that are used to deploy provisioning.
- The utility ProvisioningWebConfigFileSelector.cmd, which you use to set the appropriate configuration file for your configuration type.
To select the deployment type:
- Open a Command Prompt window and change to the <provisioning_install_location>\Provisioning\ directory.
- Issue the following command:
ProvisioningWebConfigFileSelector.cmd CONFIGURATION
where
CONFIGURATION specifies the deployment type.
For example:
ProvisioningWebConfigFileSelector.cmd F5
The utility replaces the InForm SDK\Provisioning\web.config file with one of the following files.
Deployment configuration options
Deployment type
Deployment type configuration option
Config file
Details
Default
SECURE
Web_secure.config
- Secure configuration for client requests sent over the Internet.
- Supports HTTPS transport using SOAP 1.2.
- Requires a Username Token in the SOAP Security header for providing the user name and password credentials to authenticate a request.
Load balanced
F5
Web_secure_F5.config
- Secure configuration for client requests sent over the Internet using a network load balancer.
- Supports HTTPS into the network load balancer and HTTP out of it using SOAP 1.2.
- Verifies that the study name in the URL sent to the network load balancer matches the study name parameter in the SOAP request.
LAN access
UNSECURE
Web_nosecurity.config
- Unsecure configuration for client requests sent over a LAN from behind a firewall.
- Supports HTTP transport and SOAP 1.2.
- Does not perform request authentication.
