Updating sites
To update existing sites:
- Use the PutProvisioningData operation.
To update existing users and return an identifier set for each site:
- Use the PutProvisioningDataAndGetIdentifierSets operation.
Note: Use PutProvisioningDataAndGetIdentiferSets if the returned identifier sets are used within the client. The operation is significantly slower than PutProvisioningData.
Usage—for both operations:
- Specify one or more MedML <SITE> elements for existing sites.
- If the site NAME you specify exists, the site is automatically updated.
- Site NAME values are case-sensitive. If the name you specify does not exactly match an existing name, and you also specify MNEMONIC, STARTDATE, and TIMEZONE, a new site is created.
Note: To change the Mnemonic, use UpdateSiteNameAndMnemonic.
Values: SITE element—Update site |
Field |
Required? |
Comments |
NAME |
Yes |
ADDRESS |
No |
ADDRESS2 |
No |
CITY |
No |
STATE |
No |
STATE and PROVINCE are mutually exclusive. |
PROVINCE |
No |
ZIPCODE |
No |
ZIPCODE and POSTCODE are mutually exclusive. |
POSTCODE |
No |
COUNTRY |
No |
PHONE |
No |
TIMEZONE |
No |
STARTDATE |
No |
ENDDATE |
No |
SVAUTOSELECTRATE |
No |
SVFIRSTNSUBJECTS |
No |
SITEDATEFORMAT |
Yes |
STUDYLOCALE |
No |
A site's STUDYLOCALE cannot be changed after any data is entered for the site. This means that the value can be changed until the first Submit of a screening form for the first candidate subject. When updating a site, include this attribute only if no data has been entered for that site's study. |
USERNAMEORDER |
No |
If the client does not specify a value, the existing value is used. |
APPLYLATESTSTUDYVERSION |
No |
