Verifying the installation
Note: You must choose the deployment type before verifying the installation. For more information, see Deployment types.
To verify the installation:
- Check IIS to make sure that the sdk and sdk\provisioning virtual directories have been successfully created.
- If you are using the Default deployment, ensure that you have configured the TLS certificate for the sdk\provisioning virtual directory. For more information, see Default deployment.
- Retrieve the web service help page for the User Management Interface. This procedure can be used to determine connectivity, especially when the provisioning service is hosted behind an F5 load balancer.
For example, to retrieve the help page for trial rdinformprov004, browse to
https://<myserver>/rdinformprov004/sdk/provisioning/UserProvisioningService.svc?
