Opening or deleting a set of candidate queries
To open or delete a set of candidate queries:
- In the Navigation pane, click Queries.
The Query Listing appears.
- In Query Status, select Candidate to filter only the candidate queries.
- Click Action View.
A checkbox appears to the left of each query and the Action and Reason fields appear at the bottom of the page.
- Select the checkboxes to the left of the queries with which you want to work.
Note: To select all queries at once, check Select all checkboxes icon at the top of the page (
). - For Action, select the action you want to perform. The rights you have as a user of the InForm application determine which actions appear in the drop-down list.
- For Reason, select a reason from the drop-down list or enter a textual reason for the change.
- Click Submit.
