Setting up your password recovery information
Note: The password recovery feature is available only if your trial has been configured to allow it.
Password recovery information is used to confirm your identity if you need to change an expired password or if you forgot your password and want to reset it.
- In the navigation pane, click your user picture or user name.
The Change Password page appears.
- In the E-mail address field, type your email address.
This is the email address where you want instructions for resetting a forgotten or expired password to be sent.
The email address must be at least three (3) characters long and contain the at (@) character.
When an email address associated with your user account is updated using the InForm user interface or MedML Installer utility, a notification email is sent to the old address to alert you that your email address has been modified.
