Changing your password
- Log in to the InForm application.
For more information, see Logging in to the InForm application.
- In the navigation pane, click your user picture or user name.
The Change Password page appears.
- In the Password field, type your current password.
- In the New password field, type your new password.
Passwords should have a minimum of 8 characters. For security reasons, Oracle recommends using a combination of letters, numbers, and non-alphanumeric characters. Passwords are case-sensitive.
The password must meet the requirements set by your trial administrator. For more information, see Guidelines for choosing a password and Password configuration options.
- In the Confirm new password field, type your new password again.
- Optionally, in the E-mail address field, type a new email address.
This is the email address where you want instructions for resetting a forgotten or expired password to be sent.
The email address must be at least three (3) characters long and contain the at (@) character.
The system uses the information in the Password Recovery Information section to confirm your identity when you need to change an expired password or if you forgot your password and want to reset it.
Note: The password recovery feature is available only if your trial has been configured to allow it.
- Click Submit.
