Queries
The Queries page enables you to create, respond to, change the status, or review the details of queries on a specific form data item, in accordance with your responsibilities and rights in a trial. The detail page provides information about the current status and the history of queries on the item. In this tour, the CRC user can answer queries, and the examples reflect the version of the Queries page that supports this activity.
To view the page:
- Click the query icon in the far-right column of a form item that has a query. The following table describes the different query icons.
Icon
Description
Gray icon—Appears in the far-right column of a form item without any queries against the item. Click the icon to enter a query.
This icon appears only if you have the right to issue queries.
Yellow icon—Appears in the far-right column of a form item if a query has been entered against the item and the query is not closed. Click the icon to view or update the query.
Green icon—Appears in the far-right column of a form item if the item has a history of queries.
- For site users, indicates that there are no open queries.
- For sponsor users, indicates that all queries have been resolved.
Click the icon to view the query history.
Things to note
- Current data value—The current value of the data item appears at the top of the page.
- Query History—If more than one query has been issued on an item, the history list enables you to view details about each query.
- Query details—The Query section provides details about the query selected in the History List. The appearance of this section varies with the type of query activity for which you are responsible, and with the state of the query.
For example, if you have been assigned the right to answer a query, as in this example, a row called Answer Text includes the controls for selecting or entering an answer. After you have submitted an answer, the Answer Text row becomes a read-only section in which your answer is visible, and the Query State changes to Answered. If you have been assigned the right to issue a query, the Query section includes data entry controls in the Query Text row.
- Command buttons—The command buttons in the Content-specific pane enable you to submit a query response or to return to the form.
