The answer to a query is unacceptable
If a response to a query does not resolve the issue that the query points out, you can reissue the query as follows:
- Navigate to the Query page for the item you are reviewing, as described in Closing a query.
- From the Action drop-down list, select Reissue Query in Open State.
- From the Reason drop-down list, select a reason for reopening the query, or select Other and type a reason.
- Click Submit.
