Form help
Form help is an optional feature that enables you to display the part of the documentation for your trial that describes a particular form item or page. If your trial is set up with this feature, you can navigate directly from the form item or page to the trial documentation.
To display the page:
- Click the underlined text of a form item or page.
The InForm application document window opens and displays the part of form help that describes the item.
Things to note
- Contents—Form help contents appear in the Table of Contents pane of the document window. To display a specific help topic, click its link in the Table of Contents pane. In this example, help is organized by form.
- Page indexer—The page indexer is a multi-part control on the bottom left side of the Content-specific pane. By clicking different parts of the control, you can move through the pages of form help.
