Sequence numbers
The InForm application generates numbers for tracking screened patients, enrolled patients, and randomization drug kits. As new patients are added to the system or randomized, the InForm application automatically assigns sequence numbers by using a numbering scheme that you can specify.
The InForm application includes default sequence number formats for screening and enrollment numbers, and configuration of these types of numbers is optional. If you configure the InForm application to support randomization, you must specify the sequence number format. For information on how to specify sequence number format, see Managing numbering.
