Managing numbering
The InForm application automatically generates screening and enrollment numbers. Additionally, the InForm application can generate drug kit numbers when patients are randomized. Each of these numbering types is configurable.
To set up numbering in the InForm application, the following tags are required:
- SEQUENCETYPE—Defines types of sequence numbers. The default sequence types are part of the Base installation of the InForm application.
- SEQUENCE—Defines specific sequences within sequence type. The default sequences are also part of the Base installation.
- SYSCONFIG—Defines a system configuration variable that specifies the scheme for formatting a sequence number.
