Creating sequence types
The default sequence types are part of the Base installation of the InForm application. No additional setup is required. When you install the InForm application, the sequence types for screening, enrollment, and randomization are loaded with the following tags:
<SEQUENCETYPE SEQUENCETYPENAME="Screening"/>
<SEQUENCETYPE SEQUENCETYPENAME="Enrollment"/>
<SEQUENCETYPE SEQUENCETYPENAME="Randomization"/>
