Creating a sponsor
Create a sponsor definition for the organization sponsoring the trial. The syntax of the SPONSOR tag is shown below.
<SPONSOR
NAME="name"
[PROGRAM="program-name of trial"]
[THERAPEUTICAREA="therapeutic area of trial"]
[NOTE="notes"]
[ADDRESS="addr1"]
[ADDRESS2="addr2"]
[CITY="name"]
[STATE="name"]
[PROVINCE="name"]
[ZIPCODE="code"]
[POSTCODE="code"]
[COUNTRY="name"]
[PHONE="num"]
[ALTPHONE="num"]
[FAX="num"]
[EMAIL="addr"]
[LANGUAGE="name"]
[LOGOFILE="file"]
[LOGOTYPE="GIF|JPEG|TEXT"]>
</SPONSOR>]
To define a sponsor:
- Start the block by opening the <SPONSOR tag.
- Enter the NAME. This is the name of the organization and must be unique among sponsors.
Note: NAME is the only required attribute.
- Define the sponsor’s contact information by specifying the address, telephone numbers and other attributes. Add as many of these as are appropriate. Note that if you specify a logo file, you must also specify its type.
- Close the SPONSOR tag.
