Defining system configuration settings
The settings of configuration parameters specify customizable, system-wide InForm behaviors. Default system configuration settings are installed with the Base trial in the core_SystemConfig.xml file.
This section describes how to set configuration parameters. For a description of each specific parameter you can set, see the SysConfig tag definition in the MedML online Help.
