Loading sequence number formats
To load the sequence number format into the database, include a SYSCONFIG element for the sequence number format in the .xml file used to set configuration variable values. The following shows the default format for drug kit numbers under Simple Central randomization that appears in the core_SystemConfig.xml file in the XMLBase directory of the InForm application installation.
<SYSCONFIG CONFIGNAME="RandSimpleCentral"
TYPE="0"
VALUE="SC:RND-%q"/>
