Examples
SC:RND-%q
Randomization sequence number for a Simple Central randomization scheme. Each number consists of the string RND and a sequential number, for example: RND-12.
CS:RND-%t-%q-PF105
Randomization sequence number for a Central Stratified randomization scheme. Each number consists of the string RND, the stratification code, a sequential number, and the trial name, PFST, for example: RND-CS_WT150-12-PFST
SN:SCR-%s-%05q
Screening sequence number. Each number consists of the string SCR, the site mnemonic, and a five-digit sequential number that is left-filled with zeroes, for example: SCR-PF-00012.
Note: Randomization number configuration is required, if you are configuring your trial to support generating drug kit numbers. If you do not configure patient and screening number formats, the InForm application uses the following default formats:
Screening number—SN:SCR-%s-%q (the string SCR, followed by site mnemonic, followed by generated number)
Patient enrollment number—PN:ENR-%s-%q (the string ENR, followed by site mnemonic, followed by generated number)
