Adding a user to a group
After a user is created, you can assign the user to a query group, signature group, or reports group:
- In the Trial Objects window, click the Admin icon.
- In the User Group Properties column, click the Properties link for the user you want to assign to groups.
- On the User Group Selection page, select the groups to which you want to assign the user:
Task
Action
Assign the user to a signature group
Select the group from the Signature Group Association list.
Assign the user to a query group
Select the group from the Query Group Association list.
Specify the types of reports the user can generate
Select the report types from the Reporting list.
- Click Submit.
