Removing a user from a group
To remove a user from a group:
Note: You can only remove a user from a group by using the InForm application user interface or the Admin user interface in the InForm Architect application. You cannot remove a user by running the MedML Installer.
- In the Trial Objects window, click the Admin icon.
- Click the Groups tab.
- In the Members column, click the Change link for the group from which you want to remove the user.
- On the Change Membership of Group page, select the user's name in the group members list on the left, and then click the Remove button. To select more than one user at a time, hold down the Ctrl key while selecting each name.
- Click Submit.
