Cutting, copying, and pasting
The InForm Architect application makes it easy for you to reproduce component definitions that you use in more than one location by providing the ability to cut, copy, and paste the following:
- Form component definitions.
- Visit definitions (copy and paste only).
- Component properties in the Properties window.
- Text strings in rule and execution plan scripts.
Except as noted, you can cut, copy, and paste by using the standard Edit menu commands or shortcut keys:
Action |
Edit menu command |
Shortcut key |
Cut |
Cut |
Ctrl + x |
Copy |
Copy |
Ctrl + c |
Paste |
Paste |
Ctrl + v |
