Form component definitions
The InForm Architect application enables you to copy the definitions of form components from one form to another or from one location within a form to another. You can either copy an existing component and use it as is in another location, or create a new component based on the composition of the original component. You can copy and paste components by using the Microsoft Windows Clipboard or by duplicating objects in the Trial Objects window.
