Enrollment form
When you create an enrollment visit and form, well-known UUIDs are required in the visit and form definitions. The required UUIDs appear in the table that follows. The InForm Architect application automatically provides the UUID properties in the visit and form. When you create an enrollment form section that contains the Patient Number data entry item, you must include the UUID shown for the section.
Note: A trial can have only one Enrollment form.
Component |
UUID |
Enrollment visit |
D882CE3A-0F42-11D2-A419-00A0C963E0AC |
Enrollment form |
D882CE3B-0F42-11D2-A419-00A0C963E0AC |
Enrollment form section that contains the Patient Number data entry item |
ABCFA388-223A-11D2-A426-00A0C963E0AC |
The Enrollment form can include an editable Patient Number item. The Patient Number item is optional. If you do not include a Patient Number item, the patient number is assigned automatically by the InForm software.
If the Enrollment form includes an editable Patient Number Item, that item requires the following UUIDs.
Component |
UUID |
Patient Number item |
3D25EE4C-7F1B-11D2-A728-00A0C977C64B |
Patient number textbox control |
433DAFF6-7F1C-11D2-A728-00A0C977C64B |
