Patient ID form
The Patient ID form enables users to modify the patient number and patient initials that appear in the top right corner of each form. To set up this form, use the following UUIDs:
Component |
UUID |
Visit containing Patient ID form |
03B0D5D8-7F2C-11D2-A728-00A0C977C64B |
Patient ID form |
06702B62-7ED6-11D2-A728-00A0C977C64B |
Patient ID section |
3D25EE4B-7F1B-11D2-A728-00A0C977C64B |
The Patient Number item used on the Enrollment form |
3D25EE4C-7F1B-11D2-A728-00A0C977C64B |
Patient Number text box control, if the section contains the Patient Number item used on the Enrollment form |
433DAFF6-7F1C-11D2-A728-00A0C977C64B |
A Change Initials item |
D959FE72-7F1C-11D2-A728-00A0C977C64B |
Change Initials text box control, if the section contains a Change Initials item |
433DAFF7-7F1C-11D2-A728-00A0C977C64B |
