Sequences
The InForm application automatically generates enrollment, query, randomization, and screening numbers as a trial progresses. These numbers are generated according to a sequence established in a Sequence definition and loaded into the database in the Base trial. The required UUIDs define the enrollment, query, and screening number sequences:
Component |
UUID |
Query |
5B7D4EB4-0465-11D2-A414-00A0C963E0AC |
Enrollment |
EB75B898-078B-11D2-A417-00A0C963E0AC |
Screening |
F7F1B3B8-0B5C-11D2-A418-00A0C963E0AC |
