Study Completion form
The Study Completion form records the last time the patient was seen and whether the patient completed the trial. If the patient did not complete the trial, the Study Completion form records the reason for not completing. Use the following UUIDs in the definition of a Study Completion form.
Note: The trial must contain a Study Completion form for the standard Patient Status and Patient Dropout reports to show patient status correctly.
The UUIDs in the Study Completion form are independent of study versions and apply to all patients in a trial; therefore, you cannot change study completion metadata by creating a new study version.
The following table shows the required components for defining a Study Completion form:
Component |
UUID |
Visit in which the Study Completion form is included |
F4699051-69E2-11D2-8FB5-00A0C977C66A |
Study Completion form |
7314A6A5-316E-11D2-8F9A-00A0C977C66A |
Control to indicate completion status |
PF_SC_COMPLETECTL |
Element objects defining the values and display text for study completion or noncompletion |
Control to indicate the reason the patient dropped out of the trial |
PF_SC_REASONCTL |
Text resources mapping the internal values of noncompletion reasons to the text of column headings on the standard and ad hoc patient dropout reports |
PF_SC_REASONCTL_internal_reason_value Internal_reason_value is one of the following:
