Assigning users to groups
To assign users to a group:
- In the Trial Objects window, click the Admin icon.
- Click the Groups tab.
- In the Members column, click the Change link for the group for which you want to update membership.
- On the Change Membership of Group page, modify group membership as necessary:
- To add users to the group, select the users' names in the users list on the right then click the Add button. To select more than one user at a time, hold down the Ctrl key while selecting each name. To deselect a user while preserving the selection of other users, hold down the Ctrl key while clicking the name again.
- To remove users from the group, select the users' names in the group members list on the left then click the Remove button. To select more than one user at a time, hold down the Ctrl key while selecting each name. To deselect a user while preserving the selection of other users, hold down the Ctrl key while clicking the name again.
- Click Submit.
Note: An alternative method for changing group membership is to update the group membership of a specific user. For details, see Managing group assignments.
