Creating item groups
Item groups are sets of items that you group together so that you can assign a display override to them. Display overrides enable you to specify that, for a particular rights group, the group of items that makes up an item group is Hidden, Editable, or Read-Only. This designation overrides the rights conveyed by membership in the rights group and also overrides the display properties of the items in the group. For additional information about display overrides, see Assigning display overrides to rights groups.
To create an item group:
- In the Trial Objects window, click the Admin icon.
- Click the Groups tab.
- Click Add Group.
- On the Groups detail page, select ItemGroup from the Group Type list.
- In the Group Name box, enter the name of the group.
- In the Group Description box, enter a description of the group.
- Click Submit.
