Assigning items to item groups
To assign items to item groups:
- In the Trial Objects window, click the Admin icon.
- Click the Groups tab.
- In the Members column, click the Change link for the item group for which you want to add or change items.
- On the Change Membership of Item Group page, modify item group membership as necessary:
- To add items to the item group, select names in the items list on the right then click the Add button. To select more than one item at a time, hold down the Ctrl key while selecting each name. To deselect an item while preserving the selection of other items, hold down the Ctrl key while clicking the name again.
- To remove items from the item group, select names in the item members list on the left then click the Remove button. To select more than one item at a time, hold down the Ctrl key while selecting each name. To deselect an item while preserving the selection of other items, hold down the Ctrl key while clicking the name again.
- Click Submit.
Note: An item can belong to only one item group.
