Patient ID information
This section describes:
- How to enable users to create and edit patient numbers.
- How to allow users to change the current Patient ID after enrollment.
- How patient identification information interacts with the patient record transfer activity.
If you do not create the definitions described in this section, the InForm application automatically generates patient numbers by using the patient number Sequence definition loaded into the database as part of the Base trial.
