Patient Initials data entry item
To enable users to create and edit patient numbers, set up the Patient Initials and Patient Number data entry items on the Screening and Enrollment forms.
The Patient Initials data entry item is a required item on the Screening form. When you define the Patient Initials item, the following requirements apply:
- Attach the calculation Rule that determines screening success or failure to the Patient Initials item.
- If you are mapping Screening form data items to another form by using ITEMMAP tags in the StudyVersion definition, do not map the Patient Initials item.
- Use the following UUIDs to define the Patient Initials item:
Component
UUID
AEB64F16-127C-11D2-A41C-00A0C963E0AC
Patient Initials textbox control
AEB64F17-127C-11D2-A41C-00A0C963E0AC
