Patient Number data entry item
To enable users to create and edit patient numbers, set up the Patient Initials and Patient Number data entry items on the Screening and Enrollment forms.
The Patient Number data entry item is an optional item on the Enrollment form. If you do not create a Patient Number item, or if a user leaves the item blank and overrides the enrollment failure, the InForm application automatically assigns a patient number based on the default or specified sequence number format for patient numbers.
If you create a Patient Number data entry item, the following requirements apply:
- Do not attach the calculation Rule that determines enrollment success or failure to the Patient Number item.
- Ensure that the Patient Number item is in the same visit, form, and section of the Enrollment form as the item to which you attach the calculation Rule.
- If you are mapping Enrollment form data items to another form by using ITEMMAP tags in the StudyVersion definition, do not map the Patient Number item.
- Use the following UUIDs to define the Patient Number item:
Component
UUID
Patient Number item
3D25EE4C-7F1B-11D2-A728-00A0C977C64B
Patient number textbox control
433DAFF6-7F1C-11D2-A728-00A0C977C64B
