What is involved
Before you can create a custom report, you need to know how to use a language like Visual Basic Script (VBScript) or Javascript to create ASPs that define objects and SQL queries. This section explains the interface you must use to define instances of the Reporting COM object of the InForm application, and the specific syntax that must be included in your ASPs. Several examples (written in VBScript) of retrieving and formatting different data are also provided.
