Output formats
Once you have determined what information you want to extract, you can display the output as either of the following:
- Text—For example, you can write the data directly to an HTML table or as an XML string, and specify formatting,
- Graphs—You can choose a pie chart or a horizontal or vertical bar chart layout.
